Sliding doors, with sliding bug screen panel, how
Probably not, but just in case: is there any clean way of adding a sliding bug screen panel (which needs to show in 2D/3D views and schedules) to an Archicad library sliding door? I was hoping there could be a way of faking it with the window shutters, but can find none.
There is a manufacturers' object that does produce the screen panel so I could use that, but the GS library doors and windows have some other advantages and I was hoping to be able to do everything with just the GS library.
1 REPLY 1
Hi @Ignacio Azpiazu , can you explain more with screenshots for the problem and desired solution?
AC 28 INT 3110/WIN 11
