Sloping Roof edge and trim
rgarand
Hi all,
I have a simple, yet complex in archicad, roof edge trim detail I am trying to work out. Any suggestions on how to accomplish this will be appreciated.
Here is what I have tried so far:
1. I have created a custom profile of the metal edge that I want to extrude along the roof edge.
2. I used profiler to extrude the profile to my desired length..
3. I then added some of the famous ROTX, ROTY, ROTZ items in GDL so that I could rotate it any way that I wanted.
This seems to work ok.
See the attached picture...basically I need to have a roof trim, which has a profile, angle that trim in plan and have it slope to match the roof edge.
Would any of you done this differently?
Robert J. Garand
ArchiCAD USA 28-Build 3110 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
I wouldn't bother with Profiler. I'd just use the beam tool with a complex profile (the new tool). Beams can be sloped and spun (pitched and rolled in aviation terms) so they should be able to do what you want. No need for GDL.
rgarand
Thanks Matt!
The beam with custom profile works much better and even cleans itself up too.
Robert J. Garand
