2006-09-07 11:19 PM - last edited on 2023-05-25 04:36 PM by Rubia Torres
2006-09-07 11:52 PM
mjasus wrote:
I built a square column and beams in Archicad, but have been having a lot of trouble trying to figure out how to use the Solid Element Operations tools. I want to be able to notch the beams and post by subtracting volumes from them etc.
I can get the SEO tools to do this in the 3D window, but when I save as an IFC to work in CadWork (the other program we use here) the notches are not there. It seems like the notches are not truly cut in the 3D beams and post.
I really need a way to permanently notch these posts etc for the export to IFC.
as an aside, I can use the SEO tools on the FrameWright timber beams and columns and the cuts and notches export fine to IFC.
Anyone know what I'm doing wrong or if maybe I need to specify posts and beams differently?
I read about layer and intersection priority settings, buit that just confused me even more.
Thank you
Manny Jasus
2007-03-08 04:55 AM
2007-03-08 04:52 PM
2007-03-08 05:28 PM
2007-03-09 05:02 PM
