‎2016-01-08
04:01 PM
‎2023-05-24
08:44 AM
Rubia Torres
‎2016-01-08 04:02 PM
‎2016-01-12 09:39 AM
‎2016-01-12 02:54 PM
‎2016-01-12 06:38 PM
‎2016-01-12 10:15 PM
NCornia wrote:This was really neat!
Hi Ben,
There are many ways to model complex situations. It is possible there is a better way to get the result you are after, but see the image below for one possible solution. Of course each solution may have its pros and cons. You will need to decide what works best for you.
Keep in mind that the more SEOs you add to a model, the more calculation will be required in 3D. So if you develop a large number of intersections like the one below then you may or may not notice performance slowing in your 3D model.
One way to improve performance:
- Split the corner pieces from the walls; select the corner pieces and save as a single object. See
- The single object may be re-used at all similar corners eliminating the need to repeat redundant SEOs throughout your model.
- By placing objects at the corners you may also keep all exterior walls on the same layer instead of 2 as I have shown below.
- One decision will be the floorplan representation. You will need to edit and cleanup the 2D Symbol of the corner object. See
- Depending upon the result you may or may not need to take additional measures to cleanup the floorplan intersections at corners. But this is true for SEOs also.
There may be other considerations to be weighed when using this method that you may discover as you create your design. So if you use the method below, you might report the pros and cons of your experience.
I hope this helps.
Best regards,
‎2016-01-13 02:44 PM
