Solid element operations line weight issue
TMAdams2
Good day,
I’m having an issue with lineweights when using SEO to cut the site mesh - the line between the objects always adopts the lineweight of the mesh. It doesn’t matter which element is set as the operator or target, I’ve tried switching them. How can I make it so my slabs retain their own lineweight?
1 REPLY 1
@TMAdams2,
Which Archicad version are you using? I tried it in Ac28.2 INT and it works as expected for me.
If the Building Mass is the Target, the Mesh is the Operator, Operation is Subtraction, The Building Mass will be cut, and its countours lying on the surface of the Mesh will be the proper Pen.
Note that in this case, I did not cut the site Mesh so no new edges were created in the Mesh. The goal is to cut the Building Mass so it will have contours above the level of the Mesh.
Setup info provided by author
