Read more
SOLVED!
Solid operation tool - with renovation tool ?
Hi is there some way how to use Solid Operation Tool with Renovation filter ?
For example I have existing terrain and would like to make hole with SOT only renovation filter with new construction and be possibility to switch off this SOT
Right now the SOT can't be turn off and stay for all filters
Also I like using renovation filter for making more alternatives and this will be useful know it
Thank you 🙂
P.S.: I know that I can make smooth ground and then hole but this is demands from my boss doing this type of ground
AC 7 - 27 SWE
iMac (Retina 5K, 27-inch, 2020),
3,6 GHz 10-Core intel Core i9, 64 GB 2667 MHz DDR4, AMD Radeon Pro 5700 XT 16 GB
10 REPLIES 10
runxel wrote:
Maybe this is possible with a custom object that get's a switch from the MVO
I proposed a Link/Unlink Operation and Operator option for the SEO dialog box. I don't really know if it is feasible, but IMO this would be the place for this option.
Erwin wrote:
Renovation projects are rarely BIM for us.
I think this is where they are most useful. i.e. Here in Europe it is usual to use wall ruins as the base for new ones. With this SEO capability, modeling and extracting quantities takeoffs would be e much more easy.
