‎2011-08-20
05:57 PM
‎2023-05-25
04:51 PM
Rubia Torres
‎2011-08-21 01:51 PM
‎2011-08-21 10:10 PM
laszlonagy wrote:That should work, yes but why not using Edit Stair? What is Edit Stair for? This function has no problem in 14 but it's not working in 15. Sorry but this smells like a bug for me.
Do not use the Edit Stair button to achieve this. Instead, select the Stair and go to the Stair Settings Dialog and change the parameters there. That should work.
‎2011-08-22 01:19 AM
‎2011-08-22 01:46 AM
compu wrote:It's always worked this way to my knowledge. If you change the parameters via Edit Stair, then you'll need to select another stair from the browser area, and then re-select the stair you just edited -- this assigns the stair the default settings (as you just changed via Edit Stair).
‎2011-08-22 10:47 AM
‎2011-08-30 11:58 PM
Laura wrote:Something changed/wrong in 15 I mean, I was happy with 14 about this Edit Stair stuff.
‎2011-08-31 12:04 AM
zeropointreference wrote:Nothing happened. Changing any value in Symbol Settings is NOT effective!
What happens if you change the symbol type to symbol 7 or 8 out of the menu on the left around the 40second mark of your video?
‎2011-08-31 12:14 AM
‎2011-09-02 12:33 AM
Laura wrote:Are you sure? Have ever tried anything on any stair in AC14 right after my post? =/
Yes, the geometry of the stair will change, BUT NOT THE 2D DISPLAY SETTINGS -- it's always been this way, even in AC14.
