Source View
Hello does anyone know how to change a source view after something has already been drawn.
Problem: the issue is that when i draw my framing plans i want to see the floor walls below, example: first floor framing plans below you would see your basement walls. However, i am seeing the floor above. the source view says that but i cant change it anyone out there know how to fix this
3 Replies 3
I'm lost, what exactly are you trying to do?
Im trying to show the walls of the floor below while printing the framing plan. The template set it up right now they are shgowing the walls above
Link
This is not possible AFAIK. You'll need to recreate the view, which is pretty easy - just double click on the existing view, then drag the other viewpoint over in your Organizer. If it's already placed as a drawing on a layout, just use the drawing manager to relink it to the new view.
Link.
