2006-01-16 03:25 PM
2006-02-02 01:43 AM
2006-02-02 05:20 AM
2006-02-02 07:03 AM
Seiss wrote:I have been using the SE library for some months now, and I haven't found this to be the case. Are you sure you're using the latest patch and the latest library?
I have MANY more AC crashes and bug reports with the SE library then with the standard library...
...but on the fireplace object, the contour pen was so thick that all you could see was the pen width. I hope this was an exception and not the rule.You may want to check your pen settings. The block was probably created with some lines that you had redefined (either intentionally or by mistake) to a thicker setting. All the linetypes should be modifyable. Depending on your situation, you could open the block and make the pen settings permanent. Then save it as a new block. Then, when you open it again (the new block), it should automatically come in with the proper pen settings so you won't have to change it again.
2006-02-03 04:52 AM
