‎2006-08-10
12:22 AM
‎2023-05-23
05:14 PM
Rubia Torres
‎2006-08-11 12:05 AM
Rod wrote:
And before Ben says it's "pilot error" again.
Rod wrote:that? was nothing . . . see me when i'm really fired up . . .
It was good to see young Ben vent his spleen the other day.
‎2006-08-11 05:49 AM
g.h.design wrote:I don't know if this is related.
Going to document every area where I notice slowness today.
Dimensioning.Significantdelay when clicking on a node to manually dimension a wall w/ windows doors. I click a node and have to wait s....e....v.......e.....r.........a.......l seconds before the dimension point shows on screen and I can move on to the next one. Wanted to add that sometimes (1/4 of the time) the click and placement are essentially instantaneous.
‎2006-08-11 08:53 PM
‎2006-08-11 10:07 PM
‎2006-08-13 06:25 PM
‎2006-08-16 06:12 PM
‎2006-08-16 07:08 PM
In hesitation I mean I click something, it is selected but I cannot drag it it until some process that is running in the background completes itself. This takes many seconds.Quoted myself from another thread. Seems appropriate here.
One of the processes that is linked to the hesitation is the refreshing of the information palette that I usually have open full length so that I can see all settings in one glance. If I click a door for example, the door will highlight and the information palette will start to refresh. I can actually watch the refresh progress down the info palette. When the refresh is completed then, and only then, can I drag or move or do whatever to the door. When I close the info palette, speed increases but still some lag between when I click and when I am able to effect change on the selection. The lag time is in the seconds, sometimes 3 or four seconds. Very noticeable and inhibiting to my workflow as I am used to moving very quickly. In 9 I can move very quickly, in 10 I cannot. It just is not fun where it used to be. (palette size related thus bad on my 30" monitor)
I believe the other processes that are linked to the slowdown are the new highlighting features (I like them but have them turned off to try and speed up my basic clicking and dragging)
In 9 the refreshing of the palette happens after the ability to move the item is established. You can watch it happen. Maximize the information pallette (on small monitor make it large enough to see all information at a glance). Click something and you wont be able to move it until the information palette refreshes. In AC 9 watch and if you click and drag an item the info palette won't refresh until you have completed the action. Different priorities that I assume have changed because of all the highlighting and palette changes.
I believe this is a bug. The ability to move an item should take priority over all other background processes 99% of the time. Only one time in one hundred do I want to hesitate before moving or editting an object. It does in 9 but not in 10.
‎2006-08-16 09:36 PM
‎2006-08-22 07:36 AM
‎2006-08-22 01:48 PM
