Speed helps and Lightworks lost...?
Does someone have a simple keystroke control that:
1. Cancel's a tool, so that one does not need to go all the way to the top of the tool box to cancel and do another command..?
2. Activates all of one tool's type at a time ...ie: all lettering
On an nother direction how does one get the background picture(s) to appear behind the image when using Lightworks....?
Thanks, Paul
2 Replies 2
Dwight
in version 9 you can create shortcuts for everything. Look for arrow tool/toggle last tool. I use number pad 5.
For selecting all the text, simply "Select All" with the text tool active. You can work in any text box while they are all selected. Easiest way to select..... never need to hook a node....
Dwight Atkinson
Djordje
Esc, assuming you are on ArchiCAD 9
With the appropriate tool active, CTRL A
Set the required image as the background in your rendering.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
