Split Levels
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2010-03-18 12:16 AM
Thanks guys!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-18 03:49 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-18 07:34 AM
Options>Project Preferences>Reference Levels
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-18 08:38 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-23 02:37 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-23 02:44 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-23 02:48 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-24 12:42 AM
Thanks for the tip guys, you've been very helpful!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-24 01:00 AM
most of my work is multi split levels.. i just use one story for the all levels and set all the walls outside the cutting plain to "symbolic cut". been doing this for 3 years and never had an issue.""""
_________________
How would you set the "symbolic cut", if you don't mind me asking.
Thanks alot!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-24 01:27 AM
mzjustjess wrote:If you have a slab at the level required you can use the Gravity function to place walls, objects etc at that level.
The difference is 540mm so it's definately under a metre...It sounds easier to keep everything on one story. Would it be the best then to move objects, slabs, doors etc in elevation/section mode or from the ie Wall Selection Settings?
If you have these things already placed and need to move them there are several ways, and they all have their own merits. Use the Elevate command (CMD+9 on MAc or CTRL+9 for PC) in plan and input the amount. Do this in the 3D window and you can drag things vertically on screen. In Section / Elevation use the Drag command.
Sometimes its easier to select a wall (for instance) and just change its base setting in the Info box, then the top plate height remains the same.
Skin a cat = many ways.
