‎2010-03-18 12:16 AM
‎2010-03-18 03:49 AM
‎2010-03-18 07:34 AM
‎2010-03-18 08:38 PM
‎2010-03-23 02:37 AM
‎2010-03-23 02:44 AM
‎2010-03-23 02:48 AM
‎2010-03-24 12:42 AM
‎2010-03-24 01:00 AM
‎2010-03-24 01:27 AM
mzjustjess wrote:If you have a slab at the level required you can use the Gravity function to place walls, objects etc at that level.
The difference is 540mm so it's definately under a metre...It sounds easier to keep everything on one story. Would it be the best then to move objects, slabs, doors etc in elevation/section mode or from the ie Wall Selection Settings?
Thanks for the tip guys, you've been very helpful!
