Spliting a roof in Archicad 17
Hi, how can i spilit a roof created with Multi plane method in ArchiCad 17.
1 Reply 1
You can't split a multi-plane roof but you may be able to edit it to get the roof you want - this could prove difficult though depending on what you need.
The easiest way is to split it into single roof planes and then you can do what you need with each plane.
