Splitting merged contour lines (mesh)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2014-10-12
10:28 PM
‎2023-05-25
04:59 PM
Rubia Torres
Is there any way in ArchiCad to split one contour line into two?
Essentially we are just talking about splitting up a polygon/mesh.
P.S. If the terms are wrong or confusing do tell me, and I can try to reword or explain more, perhaps using some screenshots or simplified example.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-10-14 10:31 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-10-14 10:52 AM
Ideally with the mesh selected so we can see the node positions on the contours.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-10-14 09:06 PM
I tried it in a new project and when I did that I could pull that node of one ridge away from the common node. Then it was possible to set the heights of the two ridges separately.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-10-15 11:47 PM
I will also try out the tip from Laszlo ASAP.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-10-17 10:24 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-10-17 10:26 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-10-17 12:11 PM
Not an ideal solution as you shouldn't be moving the contours but then they shouldn't be crossing in the first place so there must be an error from the original DXF.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-10-18 02:05 PM
Trying to drag one node affected other nodes in unintended and surprising ways, so I was unsuccessful in going in that direction. That was why I was hoping to circumvent the problem by splitting a contour line before the intersection point.
Thanks for your help anyway!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-10-20 05:35 PM
