ā2004-12-29
11:27 PM
ā2023-05-26
09:02 AM
Rubia Torres
ā2004-12-29 11:46 PM
ā2004-12-30 12:12 AM
ā2004-12-30 12:13 AM
ā2004-12-30 06:17 PM
Geoff wrote:AFAIK, Graphisoft is aware of this wish for more sensible stacking order.
Why do elements not view/stack based on their elevation?
ā2004-12-30 08:09 PM
Karl wrote:The send forward/send back (which for me is command/shift/] and command shift [ like illustrator and photoshop) but in the case of the trelles there are 20 or so pieces so I run out of stacking slots, not to mention the fact that the stacking level does not remain the same if one of the elements are edited.Geoff wrote:AFAIK, Graphisoft is aware of this wish for more sensible stacking order.
Why do elements not view/stack based on their elevation?![]()
Right now, there are a limited number of stacking levels, and elements go to particular levels by default. You have to manually use the bring forward / send backward commands to adjust them to the way you want them.
You end up getting comfortable with the F5, F6 and shift-F5, shift-F6 shortcuts if you do a lot of this stuff...
ā2004-12-31 05:38 AM
Geoff wrote:You might want to try an age old trick:Karl wrote:The send forward/send back (which for me is command/shift/] and command shift [ like illustrator and photoshop) but in the case of the trelles there are 20 or so pieces so I run out of stacking slots, not to mention the fact that the stacking level does not remain the same if one of the elements are edited.Geoff wrote:AFAIK, Graphisoft is aware of this wish for more sensible stacking order. ///
ā2004-12-31 12:10 PM
ā2004-12-31 01:19 PM
StuartJames wrote:You're right it is annoying but a quick way to do it rather than to save a plan would be to use the patch tool.
One thing we've done (on occasion) in the past to 'get round' the ANNOYING limitations of AC stacking (as Geoff has discovered) is save a 'plan 3d view' as 2d elements.
ā2004-12-31 01:31 PM
