I tried this by placing a U-shaped Stair and I tried modifying the Landing width by selecting the Boundary and adjusting it.
The curious thing for me is that if the space between the two Flight is below a certain amount, it will not allow me to do it. For example, it did not work with 200, 300, or 400 mm between the Flights, but did work when it was 900 mm, as can be seen on the screenshot. Also, in case it did allow it, it did not let me closer than 50 mm to the node on the Baseline that separates the Flight from the Landing. At the moment I could not figure out what is imposing these limitations, maybe some Landing or Connection setting, but I don't know yet.
