Stair Symbol at Different Floors
The symbol of a stair between two stories should have two different graphic representations. From the first floor to the second floor the arrow should point up, but from the second floor down to the first floor, the arrow should point down. If the stair parameter is set to all relevant stories and is placed on one floor or the other how can you have the two different symbols to show appropriately for the same stair? Thanks.
2 Replies 2
See:
http://archicad-talk.graphisoft.com/viewtopic.php?p=234951#234951
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Karl, thanks. It worked.
