2015-03-0909:20 PM - last edited on 2023-05-2504:47 PM by Rubia Torres
2015-03-0909:20 PM
I have a problem with setting the display properties of my stair :
The stair is set to display on home and one story up. That works fine, the stair appears on both stories
In "Up & down. Numbering" i unchecked "Show numbering". This removes the numbers from the home story but they still show up on the story above ! Am I missin something, or doing it wrong ?
Which Stair is this? A Stair in the default Library or a Stair you created?
Some stairs have separate Show Numbering checkboxes for the 2D above the Home Story.
Can you show a screenshot about your parameters?
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
