2010-04-20
07:17 PM
2023-05-25
04:53 PM
Rubia Torres
2010-04-20 07:48 PM
2010-04-21 06:55 AM
2010-04-21 08:21 AM
2010-04-21 08:42 AM
Dwight wrote:..................
So I'm an idiot for doing it the hard way.....
2010-04-21 09:03 AM
2010-04-21 05:08 PM
Peter wrote:I've scripted an object for this situation, including profiled perimeter, handrails, etc., but it's far from simple. I've attached a snippet from the project showing a cut-away into the central stair, which rose through an elliptical, conical central core and incorporated landings at irregular intervals. Contact me if you want something like this, but it would be done as a one-off exercise, i.e. I don't this this will be solved with generic parts.
Problem is that the profile of the wall changes, depending on elevation. I think I cannot use the function "create stair using selection", and also with the stair library I'm not sure if there is a solution.
2010-04-21 06:06 PM
2010-04-21 06:07 PM
2010-04-22 06:54 AM
