Stair tool, sloped riser face at nosing edge
This is an existing stair, from the '70s. Cast in place reinforced concrete, concrete screed, rubber flooring.
On the left the closest I am getting to so far with the Stair Tool. I can't get the sloping riser finish face to meet at a (sharp or rounded) edge with the tread finish face —instead I get that tiny overhang, which will get worse if I set a larger tread finish thickness (say screed + rubber) and almost disappear if I set it close to 0, but then because the nosing fillet is set within the thread finish thickness the fillet will almost disappear too.
What would be the way of dealing with this using the Stair Tool?
11 REPLIES 11
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Ignacio,
This is the reason why I said it is a trial-and-error process The Custom tread was not designed for this purpose (that's why I use only a very simple profile for the landing). I can give it a try to see if I can make it work somehow. Is it possible for you to share a copy of your stair (with all complex profiles you are using for the stair)?
Let me know if you need a secure link to send the file!
Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi All,
Thanks to Ignacio's file, we figure out what would be the best option in this case. Instead of using a custom complex profile to model the whole landing's finish, it can be done by using the default tread object, in this case, Tread 23, and add a Nosing: Custom Profile.
A custom profile can used as the Nosing Shape. This will give a much cleaner result in comparison to applying a custom profile for the whole landing finish. Then, with a bit more modification, you'll have the finish set up correctly on the landing.
To apply/remove the nosing at a given edge, please refer to this guide, scroll down to Define Custom Tread Segment: Front, Back, Left, Right section: https://helpcenter.graphisoft.com/user-guide/76597/
I hope this will give you an idea of how to model landing finish with custom profile!
Thank you for your contribution! Have a nice day, and stay safe!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
