Staircase - Starting from a corner
Hi, I'm having a problem building a staircase.
On the left I built a 3D staircase very simply using individual floor slabs with 2D annotation over the top. Now I'm learning about how to use the proper 3D stairs but so far I can't figure out a way to get the 3D to match the 2D. I need my staircase to have the angled corner style, but I also need the staircase to START on the angled corner like it's shown on the left. Anytime I try to manipulate the 3D stair it snaps to a straight run. Is there a tickbox somewhere to specify 'start on the corner' or a work around that anybody knows of?
Also, how do I control the style of the stair run arrow, I want to take off the little circle at the end.
I'm running ArchiCAD 22.
Thanks!
Hannah
22 REPLIES 22
I figured out how to do it.
It is indeed the way you say it Barry, the Stair must be turned back parallel to its length at the top.
In the next posts I will detail it. But this is the final result:
First of all, set all the important parameters in the Settings Dialog before starting to create the Stair, including number of Treads and the "Winder with Equal Angles" option, with 2 Goings.
Then I think it is a good idea to draw the outlines of how the Stair should look in the floor Plan, which will help when drawing the Stair Baseline. So I drew it with red on the right.
We can now start drawing the Stair Baseline. All Baseline segments will be Flight Segments.
The Stair Baseline should be on the outside boundary of the Stair.
Now, here are some GIFs (click on them to play). In the first one you will see that I try to draw the Baseline along the outer boundary, but it does not give the correct result because I run out of Treads before I could turn the Stair back 180 degrees.
So what we can do is something which I was told about by Marta Molnar from GRAPHISOFT HQ.
I make the Stair shorter so I can turn it back 180 degrees, then I modify the Baseline polygon to the desired shape (Click image to play GIF).
At the end of the GIF you can see that the Walking Line is not correct, but we will handled that later.
Now, we select the Stair in 3D and enter Edit Mode.
We select the Stair Structure, and use our little-known little friend, the Split Stair Structure command from the context menu, then split the Stair at its last Riser.
This way the Structure below the last Tread can be independently set and we will be able to turn it OFF, along with the Riser and Tread (Click image to play GIF).
While still in Edit Mode, we can now simply select the separate Stair Structure under the top step and turn it OFF. We can do the same with the Tread and Riser. (Click image to play GIF.)
So now we have achieved the desired 3D of the Stair.
All we need to do is fix up the Floor Plan Display of the Stair.
We need to go to edit mode and modify the Walking Line polyline, and possibly the Numbers (each can be individually selected, moved and rotated), plus the "DOWN" text.
This is the result, which is almost perfect, except for the fact that it is not possible to hide the Floor Plan representation of that last Tread which we hid in 3D. Unfortunately, this is a limitation, because the Stair Grid is generated automatically, and it is not possible to individually select and hide Tread edges and Riser lines.
So, all I could do is to take an old trick and just cover that last Tread on the Floor Plan with a Fill that has the same background as the Floor Plan Viewpoint. This is the final result:
Ahmed_K
LaszloNagy , very nice solution !
Archicad 27
Windows 11 professional
