OK this seems to be a bug in the fills being made available to GDL elements in their settings dialogs - it affects all objects I have tested, including custom objects so I know its not a scripting issue. Also the problem doesn't occur in the GDL Editor environment as you can actually use an fill when setting a parameters default value.
To test:
1. I drew a Cut fill on plan and saved as an object and placed. The GDL 'hard-coded' Cut Fill shows.
2. I edited the auto-script to make the fill type parametric. The Cut Fill is available in the fill selection dialog in the GDL Editor so set this to be the default parameter value.
3. The object displays the Cut Fill used as the default fill parameter in the Object Settings dialog
4. Now if I try to change the parameter value, the Cut Fills are not available in the fill selection dialog.
Apologies for the image rotation .. forum has a stupid 1600
wide x 1200
high limitation ... so my 1400 high x 1000 wide image wasn't accepted. Again, please fix the ridiculous file size limitations .. its 2011. I'm sure GS can afford a few more TB's to store the forum data. I know you can link to external sites but these links go dead in time, devaluing the refering posts
cheers,
os
	cheers,
Owen Sharp
Design Technology Manager
 | francis-jones morehen thorp
