‎2007-11-13
08:40 PM
‎2023-05-25
04:58 PM
Rubia Torres
‎2007-11-13 10:30 PM
seattleguy wrote:it's not the most intuitive of things to do -
I want to be able to see the top of the stairs from the story below, and only see the 1st half of the stairs on the current floor.
‎2007-11-14 03:39 PM
‎2007-11-14 09:03 PM
Jesikuh123 wrote:I think you may be wrong, Jesikuh
Correct me if I am wrong, ...
‎2007-11-14 09:17 PM
Jesikuh123 wrote:i never use stairmaker (the 'create new stair' option), so i know that it works for the stair objects in the library as well.
Correct me if I am wrong, but I think that ~/archiben's way (And the way I handle it) only works with the "Create NewStair."
‎2007-11-14 09:20 PM
~/archiben wrote:CORRECT!
with regard to the arrow (and here is where i start a great big <b>[censored]</b> fight!) - from a graphic convention point of view, i don't believe that the arrow should show anything other than the 'up' direction anyway . . .![]()
~/archiben
‎2007-11-14 10:43 PM
~/archiben wrote:Ummmm... except the direction of egress is typically DOWN.
‎2007-11-15 01:06 AM
Laura wrote:since i threw the ingredients together, i feel compelled to give it a stir too . . .
Regardless, we need to have more control of the 2D symbol, be it with a Stair object or StairMaker.. . . or any object. my complaints over most third party additions to archicad are usually 2D representation related. stair graphic convention joking aside, an object's representation must be incredibly flexible. all too often developers of objects have one idea about how it should look and ignore the possibility that another user might need something else.
‎2007-11-15 05:22 PM
~/archiben wrote:In commercial work, egress is typically the ONLY function of the stair (traveling between stories is what the elevator is for
egress is not a function of the stair - it's a requirement unto itself.
~/archiben wrote:Yep. And this is one thing that frustrates me about the available 2D symbols -- typically it's not one or the other: from an intermediate story, one flight goes UP and the other DOWN.
out of interest, if you had a fire escape door at a half landing level do you have one flight showing an arrow up and the other showing an arrow down all within the same stair?
‎2007-11-15 06:08 PM
another Moderator
