Stopping AC mid calculation?
TDabney
Hello -
This is probably an easy one. How do you stop AC from calculating in the 3D window, section/elevation tool and photorendering window? For example: you start a photorendering and then realize you forgot to adjust the sun angle so you want to stop it mid-way thru and restart after making some adjustments. I used to be able to type "command . (period)" to get it to stop. For some reason it hasn't worked for me for a while. I'm using Mac 10.3.1, AC 8.0v3.
Thanks,
Tom
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
19 REPLIES 19
David Larrew
As you said, in AC7.0 the hot-key was "Ctrl"+".".
Since upgrading to AC8.* I haven't needed that command (yet) - AC8.1 is much faster in most areas where I would usually have to cancel out.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
TDabney
David wrote:
In AC7.0 the hot-key was "Ctrl"+".".
I haven't tested it in AC8.* yet.
Yes - It still works for me in AC7.0, but not AC 8.0 - and I haven't been able to find a key combo that does work in 8.0 - has anyone else?
macOS 12.7
Apple M1 Max
ArchiCAD 26/27
David Larrew
This may be obvious, but... Have you tried the "Esc" key?
I think that GS re-assigned the "Esc" key function from the Snap toggle to an actual escape command.
AC 5.1-25 USA
TDabney
Yup - and about every other combo my fingers could come up with!
macOS 12.7
Apple M1 Max
ArchiCAD 26/27
David Larrew
Now you've peaked my curiosity.
As I said earlier, due to the increased speeds in AC8.1, I haven't had to find or use the old "Stop Process" command. But now I want to know where it went.
AC 5.1-25 USA
Tom
Once you start a rendering, the progress bar should have a "Stop" button next to it in the photorendering window. Doesn't that work for you?
Richard
AC26 (since AC6.0), Win10
__archiben
guys
'Cmd' + period ('.') works for me, just like it used to . . .
i can't remember having done it with 8.0.x, but it works for 8.1.
[update - that's 8.1 with panther (OSX 10.3.1)]
~/archiben
b e n _ f r o s t
It could be an issue specific to 8.0 and Panther
Unless you guys have a trick...under Windows, the ctrl-. shortcut doesn't work for me anymore - I have to actually click on the stop button during a render. And sometimes (not always), the progress bar and stop button don't appear, so there's no way to stop the process.
If I go under keyboard shortcuts, it reports that ctrl-. is assigned to the system, so it isn't as if I accidentally reassigned it to something else.
So, hey, maybe something is working better on the Mac side these days!
