mukster
Stories lining up problem
Has anyone had a problem where they draw a plan with 2 stories, and when they show one as a trace reference, they don't line up?
6 Replies 6
Patrick M
Ace
not really, no. If I have walls that need to line up from one story to the next, I usually just take stock in where the reference line is, then copy/paste them from one story to the next.
are you sure your trace ref is not shifted? try reset via the trace pallet...
mukster
How do you do that? I don't know where the trace pallet is
Ricardo Lopez
Hi @mukster
Use the Drag Reference option for a better alignment; it is in the Trace tool.
You can find the Trace & Reference palette turning on the Trace tool and then selecting Trace & Reference. You can also activate it by clicking on Window> Palettes> Trace & reference.
Ricardo López, M. Arch.
Patrick M
Ace
but you don't want to drag the reference, you want to reset the reference to its default position.
Ricardo Lopez
I completely agree to @Patrick M . The “Drag Reference” feature is used, for example, to trace over a drawing view. If you're tracing over a modeled floor plan, you need to align it using the 3D model itself.
