Story Level Marker show wrong on Sections / Elevations
Hi all,
Has anyone got the same issue as this: on sections/elevations: the Story Level Marker on all stories just show the Ground level only (see attached image)
I could fix this by turn off & turn on again the Story Level Marker but it’ll come back later.
Thanks
4 REPLIES 4
NandoMogollon
weird, try a different Story Marker and see if it works.
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Nando,
Yes I did, with other markers than Built-in Marker. This issue will come back in the day after.
Marton Kiss
This is something that we have recently addressed in the code of ArchiCAD. Sorry to hear that it affects your projects as well. A final solution will be available with the next ArchiCAD 16 hotfix to be released this Summer.
The followings might help to workaround the problem:
- rebuild the section elevation
- unload the library that has the marker, rebuild, reload the library
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
Many thanks! Look forward to the new hotfix.
Please be noted that I've got this issue since V15 to early V16. We'll probably need it to be fixed on V15 as well.
