Aaron Bourgoin
Window & Door Favorites
Do window and door favorites have to be anchored to a specific storey or can they be taught to put a header at 7' above any given storey.
We model walls that extend below the top of the floor slab and so an anchor by wall base doesn't work. The extent to which they run past the floor slab varies, so using the anchor to wall base doesn't work.
So far, I've been forced to create a favorites palette of windows for each individual floor.
Is there any way to reduce this to a single list of favorite windows with an anchor point relative to the current storey.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.33 Mac
MacOS Tahoe 26.5.2
In the favourite preferences you can set it to ignore the window/door anchor point.
You will now have to manually set your windows to anchor to the head above the storey (probably is set to that already) but as you move up and down storeys it should reset to suit each storey.
Note this will apply to all window and door favourites.
Aaron Bourgoin
Thanks Barry. I'll try that. Curious to see if this preference setting persists from one session to the next and then whether it persists once each user has set this.
We run ArchiCAD on Citrix Servers and I'm still not clear how one's preferences are remembered across the various virtual machines.
Makes me feel old.
Rhino 8.33 Mac
MacOS Tahoe 26.5.2
