2006-12-04 11:31 PM
2006-12-04 11:47 PM
2006-12-05 01:23 AM
2006-12-05 01:47 AM
2006-12-05 01:52 AM
TomWaltz wrote:no need to extract the LCF - just use the 'Open Object by Subtype...' command and navigate through the loaded object subtypes to find what you're looking for:
2) When that's not possible, extract the LCF file and use your OS's "Search" function to find the object you want.
2006-12-05 02:26 AM
2006-12-05 02:42 AM
Peter wrote:fair enough . . . here it is . . .
Hello Ben,
There must be a difference between the AUS AC 10 library
and the USA AC 10 library because there are no sub-folders
inside the Marker Symbols folder.
2006-12-05 03:12 AM
2006-12-05 04:38 PM
Peter wrote:Yes -- this is what I did, except I gave it a different name when "saving as".
I also found out where this object is stored in the USA AC 10 library by opening by sub-type, "saving as"
