ā2008-10-29 04:44 PM
ā2008-10-29 08:04 PM
ā2008-10-29 08:19 PM
ā2008-10-29 11:22 PM
ā2008-10-30 12:02 AM
Link wrote:ow, where can we get that story marker by Rod Jurich from?
Arghhh! This is a huge misunderstanding! Don't set up your story elevations as real world elevations. Please see my previous explanation on this subject here.
Link.
ā2008-10-30 12:15 AM
Link wrote:just re reading you post about the levels.. what actual reason is there for not putting the project "40,000" in the air other then ,"you shouldnt" ??
Link.
ā2008-10-30 12:24 AM
ā2008-10-30 01:28 AM
ā2008-10-30 01:35 AM
GeNOS wrote:Well basically it goes against the grain of ArchiCAD's modeling process. It all has to do with the model's relationship with the Project Origin. If we keep the project at the origin, the model is in one constant place the whole time. If we adjust the storeys, then the model is moving vertically away from the project origin.
im in AC12 and iv been setting all my projects up in the air to there real level and have not run into any problems??? is there somethign im missing?
cheers
Gene
ā2008-10-30 01:39 AM
GeNOS wrote:There is some anecdotal evidence that placing models further away from Project zero slows down your file's performance. Further placement equals even lesser performance. Eight miles is REALLY far.Link wrote:just re reading you post about the levels.. what actual reason is there for not putting the project "40,000" in the air other then ,"you shouldnt" ??
Link.
cheers
Gene
