Strange Slab Behavior
Hi all.
Can anyone tell me why I can't create a slab with an arc cut in it? I have had no trouble untill just now. No matter what I do, it comes out square?
Example:
Regards, Andrew.
Dwight
You forgot.
The attached image shows the slab pet palette where an edge can be arced.
Also, you can magic wand any form in plan to create a slab to match the shape.
Dwight Atkinson
OK, something must be going on because with magic wand it does the same thing. Let me go back and check the exisitng model.
Dwight
go for the multi-side slab, not the rectangle.
Check your magic wand setting.
Also, be sure the thing can see your arc - test with a magic wand fill
Dwight Atkinson
