fhedberg
Strange bug while copying walls?
Hi all,
I have noticed this some time ago, and it does not happen all the time and just wondering if anyone else have noticed as well.
On rare occasions when I have multiple items selected and use 'ctrl+c' to copy, any wall selected will flip on their reference line, inverting themselves. If I try again but use 'right click>copy' it all works as intended.
Easy to fix but problem is that if your not paying attention it may take a little while before you notice and might be too late to undo.
W11 Home | ArchiCAD 27 3001 AUS FULL
'C' is the keyboard shortcut to change the Construction method (reference line position) of the wall.
So it seems it is picking up the 'C' part and not the 'CTRL+C'.
I notice if I just select a wall and hold 'CTRL and press 'C' multiple times quickly and then let go of the 'CTRL" key it sometime (not always) moves the wall.
fhedberg
aahhh....that should explain it!
Just me being a bit sloppy then.
