Strange wall end behaviour
All of a sudden, walls stoped to join to each other in my project. Even if I draw them using polyline method, connections dont clear up as they should. Do I have any strange setting?
5 REPLIES 5
Probaly not, i think that u turnd off "CLEAN WALL & BEAM INTERSECTIONS"
In ac9 u can turn this on or off with F7 button but
In ac10 find this option in your menus and switch it on!!!!
If this dont solve your problem WRITE !!!!!
No, I have tried that first thing. Turning Clean wall/beam intersections doesn't make any difference in this case. If I copy/paste this walls in new project, everything is ok.
Probably the layer where you put the walls have the "wall intersections" = 0... Go to the layer manager and set the value to 1 or higher. Then tell me if it works
Thanks Braza. I never knew what those numbers are for in Layer manager . So that is it! This happened when I have imported one DWG with surveyers info into this project.
Thank you a lot.
You're welcome Luka.
One day you will be helping someone else with the same problem
Keep it up man!
