‎2006-09-11 10:54 AM
‎2006-09-11 11:09 AM
Luka wrote:
All of a sudden, walls stoped to join to each other in my project. Even if I draw them using polyline method, connections dont clear up as they should. Do I have any strange setting?
‎2006-09-11 11:57 AM
‎2006-09-11 01:11 PM
Luka wrote:Probably the layer where you put the walls have the "wall intersections" = 0... Go to the layer manager and set the value to 1 or higher. Then tell me if it works
No, I have tried that first thing. Turning Clean wall/beam intersections doesn't make any difference in this case. If I copy/paste this walls in new project, everything is ok.
‎2006-09-11 01:48 PM
‎2006-09-11 04:16 PM
