2007-08-06
08:03 PM
2023-05-23
05:06 PM
Rubia Torres
2007-08-10 12:48 PM
Djordje wrote:I used to know ArchiCAD. I implemented it into a number of architectural firms. I wrote tens of GDL objects. I even was supposed to be the national tech support of an ArchiCAD distributor, but because he thought bs was enough for the handful of users, this did not amount to a hill of beans.
At the cost of endangering my life, I will reveal the secret of initiation:
Sit for an hour with someone who knows Archicad.
2007-08-11 01:00 PM
2007-08-12 11:27 AM
2007-08-13 03:45 AM
Petri wrote:at what angle does a column become a beam i wonder?
I still can't get object-columns to be raked, but even I don't normally have things like that. The Profile Manager surely can handle such exceptional situations.
2007-08-13 08:56 AM
~/archiben wrote:Good points. The latter would be quite acceptable (maybe slightly confusing in its own way) if I only knew how to apply an arbitrary IF-class.
regardless - for anything other than vertical, you can use a 'column-profile beam' object and incline it . . .
2007-08-14 12:11 AM
Petri wrote:GDL objects already belong to an IF class based on their subtype. if i'm reading the manual correctly, they are automatically assigned that class on export . . ?
... if I only knew how to apply an arbitrary IF-class.
2007-08-14 12:14 AM
2007-08-14 12:21 AM
2007-08-14 10:49 AM
~/archiben wrote:I surely would if I only could. The demo mode does not allow exporting.
make a quick steel/column object model and export as IFC to check once and for all . . . ?
and jumping up and down abusing the power users trying help isn't the best way of solving the problem either, eh?
it would be nice if the IF class of an objects subtype was revealed in the object's tool dialogue IFC paneYes. One wonders what's it for... You don't see the IF class of some objects, you can't change it for any. What's the point, what's the b*dy point, as Basil Fawlty would once again say.
Djordje wrote:Well, I'm not really sure if I'd enjoy this Jim Jones -style in the long run.
Now if you'll excuse me, even deities can't escape the mobs, gotta hide ...
2007-08-14 01:38 PM
~/archiben wrote:I don't know. In reality, a beam cannot be used as a column.
