ā2005-06-06 05:46 PM
ā2005-06-06 06:02 PM
Tom wrote:Set the working units preference to Surveyors Unit. In the "a" field type "n 75 45 32 e". Punctuation is not needed, lowercase is OK. To do a bearing and a length: Type a. Enter the bearing as above. Lock the "a" field by typing Alt+a. Type r. Enter the length and return.
Any way to put angles in by surveyors methods: e.g. N75degrees45'32"E.
In the camera settings, the sun button has a north arrow. Does that only refer to North for shadow calculation?Nope. That's north for everything, and that's where you set it. You can also get it with the More Sun button in 3D Projection Settings.
ā2005-06-06 08:23 PM
ā2005-06-06 08:42 PM
Tom wrote:Yes. If you draw a line with an angle of N 0Āŗ 0' 0" W, it will point in the direction set in the sun dialog.
So then all surveyors information will be relative to the position of the arrow in the sun settings?
ā2005-06-07 03:32 PM
