Switched from Mac to PC
With Mac it was always easy to have a plan view, a 3D view & a section open at the same time. Now that I have switched from Mac to PC I can't figure out how to have the 3 views open simultaneously. Is it possible on a PC? Thanks n advance!
12 REPLIES 12
Thanks. I just figured that out. Going from MAC to Windows is fraught with danger!
Thanks for updating your signature, Jack. I just assumed that since you switched to PC that you switched to a new PC with Windows 10... Do note that officially, ARCHICAD 21 is considered 'compatible but not tested' on Windows 7.
The last officially fully compatible Windows 7 version of ARCHICAD was version 19:
https://helpcenter.graphisoft.com/technotes/operating-systems/windows-7/
I've not seen any (?) discussion here of people having issues with Win 7 and AC 21 ... but just be aware that it is possible that you may run into something. Good luck with the transition.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thank you Karl. I'm going from ArchiCAD 17 on Mac to ArchiCAD 21 on Windows 7 PC. Working a new job in a ten person office, all using AutoCAD on Windows 7.Most of the drafters want to learn Revit. If I can impress them with ArchiCAD I might win some converts. Bosses mostly interested in creating 3D renderings of proposed projects. Wish me luck!
