We value your input!
T-intersection on facades
Hello all
Is there a way to get rid of the vertical line on the facade while keeping the plan intersection clean? I tried increasing priority for the facade walls but it rendered floor plan intersections incorrect.
15 REPLIES 15
Rod Jurich
archimax wrote:
/... Is there a way to get rid of the vertical line on the facade while keeping the plan intersection clean?/.....
No. It is a long standing wish. Having said no, you can overcome this annoying bug by using a wall end.
I will speak to our local GDL guru and ask him to post to the depository.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Erich
Rod,
Interesting trick. Are you just using the bog standard wall end or is this something different and if so how?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Rod Jurich
Erich wrote:
/...... Interesting trick. Are you just using the bog standard wall end
No trick Erich. The 2D is just a small line for location. I turn if off in plan
after correctly placing.
After placing you can flip to either side that is required to hide offending line.
Part has been scripted by Ben Cohen. Waiting for his approval to upload.
The only thing yet to sort is to get the texture mapping looking right.
But with it set to a small length the slight irregularity in the texture is hardly noticed.
Rod Jurich
Thanks a lot Rod!
Regardless of a small inaccuracy in intersection that wall end workaround worked well for me this time (for 1:200 scale).
I'm looking forward for the scripted one.
Here is my trick.
I figured if I placed a Column in just that corner, it would do the trick and so it did.
Rod Jurich
archimax wrote:
/... Regardless of a small inaccuracy in intersection
that wall end workaround worked well for me this time (for 1:200 scale). /....
With our Wall End there is no inaccuracy in plan view, only slight
when a detailed material is selected for the walls shown in 3D.
I will post when the scripted part is available.
Rod Jurich
Rod Jurich
laszlonagy wrote:
Here is my trick. /....
Thanks Laszlo, another way to "skin a cat"
The 2D plan still needs a work around to have a clean
intersection and if the wall/walls are moved you have
another element to remember to move also.
The Wall End will automatically move with it's parent wall.
Rod Jurich
Yes, true.
You know, different tastes...
SeaGeoff
Ace
Any news on the fabled magic wall healer Rod?
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-28, M1 Mac, OS 15.x
Graphisoft Insider's Panel, Beta Tester
