License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
...THAT DARN 'ELUSIVE' REF DOT...ORANGE BALL.
rob2218
SEE ATTACHED.
THE REFERENCE DOT THAT SHOWS UP (WHICH IS MOST USEFUL BY THE WAY) WHEN MOVING OR REFERENCING GEOMETRY OF AN OBJECT, CONTINUALLY MOVES AND DISAPPEARS WHENEVER i TRY AND TOUCH IT......HOW CAN YOU "LOCK" THAT DOT IN PLACE JUST LONG ENOUGH FOR A USER TO TOUCH IT AND SELECT THE OBJECT AS THE REFERENCING GEOMETRY???
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
10 REPLIES 10
You have to run your cursor along the object it is referencing. If your cursor strays too far, it disappears.
NandoMogollon
Hi Rob
What works for me is to hit "Q" on the keyboard. That's the shortcut that forces the highlighted pale orange dot into a guideline.
See if that works
Cheers
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
NandoMogollon wrote:
Hi Rob
See if that works
Cheers
"Q" clears my guidelines (default, I think). Check your shortcuts, Rob, and assign as necessary.
rob2218
HUMM...."Q" clears grids...."Q" brings up the mischievous" dot....
ok, I'll check my shortcuts.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Shortcuts can vary between Mac and Windows. If your signature had relevant info in it you might get better answers
But as I said, if you run your cursor along the element, the "blob" will stay till you get to it.
NandoMogollon
Yep, "Q" is the default for force guide lines in PC. What is it on MAC?
Nando Mogollon
rob2218
Wow!!...whenever now I try to reference a grid line...the entire model is CRASHING like a raped ape!!!.....has crashed 5 times in the last hour and happens ONLY when I try to reference a grid line object as the referencing element to rotate my text.....humm...
i>u
Edgewater, FL!
SOFTWARE VERSION:
Show / hide guidelines
Have you installed the latest (3487) hotfix? I believe this fixed some issues with guidelines. If you added this information to your signature......
rob2218
Thanks for the "hotfix" tip....we have not installed the latest HOTfix.
hopefully that will resolve the "crashing" report this is causing.
I've sent probably 12 BUG REPORTS to GS in the last 4 hours today...hubboy.
i>u
Edgewater, FL!
SOFTWARE VERSION:
