TIP: New line in text fields
Here's one small text field tip which might be helpful;
Text in the ID-field etc. can be divided into multiple lines using '\n' as a separator, '\t' works as a tab.
10 Replies 10
TomWaltz
Wow, nice find!!! (just checking, it works for Zones too. Too bad the text over-runs the rest of the symbol))
It would be even better if that did not show up in schedules and such!
Tom Waltz
Laura Yanoviak
Darn -- I was hoping this would work for dimension strings -- no such luck...
Stress Co_
It worked on an objects text:
Marc Corney, Architect
Red Canoe Architecture, P. A.
Rod Jurich
Juha wrote:
My son often says I suffer from the odd "senior moment". Well if memory serves me correctly there used to be an "tip of the month" award.
Well I vote that Juha gets it for Nov.
And thanks to Marc also.
Just tried it and without doubt a bloody beaut tip
Rod Jurich
__archiben
you guys do realise that this is probably just a text-field bug that got through the system? i'll guarantee it gets "fixed" in the next version!
ben
b e n _ f r o s t
Rod Jurich
ben
Oh please don't be a spoil sport, Ben
Just get them to fix the other 80%ers.
Rod Jurich
Stress Co_
Juha: How did you figure this one out?
It's always worked in Section markers, for manually placing sheet number in bottom of marker. A natural progression from that perhaps?
David Maudlin
It has been part of the GDL code for a long time, see page 22 for "Strings" in the ArchiCAD 10 GDL Reference Guide.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
