TRIM WALL AND ROOF
Llian
I did it before but now I can't....why is the wall still showing on the roof after trimming. How do i get to trim to underside of the roof?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
4 REPLIES 4
David Maudlin
Lilian:
See this thread: How To Get Rid of Wall Intersections for a Clean Look.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Llian
Thanks Barry...
I am having trouble finding the Wall Settings > Model > enable End Surfaces: Override using Adjoining Walls...
David Maudlin
That setting is not relevant to the problem you posted, and is not available in AC17.
David
Llian
Thanks David.
I used the SEO instead and walls are trimmed to underside of roof.
