ā2007-06-12
07:30 PM
ā2023-05-23
03:18 PM
Rubia Torres
ā2007-06-12 08:09 PM
ā2007-06-12 08:18 PM
ā2007-06-12 10:32 PM
M_Cutrara wrote:You will probably have better results with beams. They should clean up automatically.
I AM USING ANGLED COLUMNS FOR THE PURLINS AND JOISTS.
ā2007-06-12 10:42 PM
ā2007-06-12 10:44 PM
ā2007-06-12 10:50 PM
M_Cutrara wrote:What version of AC?
You can get round beams using the Beams tool?? I tried that originally, but could not get round.
Thanks, Michelle
ā2007-06-12 10:56 PM
ā2007-06-12 10:59 PM
M_Cutrara wrote:Then the profiles will work (feature introduced in 10).
Version 10. I am very new at using this program.
ā2007-06-12 11:34 PM
Matthew wrote:Well...except that the hugely ANNOYING feature of the beam tool is that when beams are angled, the ends are plumb (vertically) cut. There is no option for square cut, which is what you typically would have in a log home and various styles of conventional exposed beam tails.M_Cutrara wrote:You will probably have better results with beams. They should clean up automatically.
