‎2011-09-12
09:28 PM
‎2023-05-23
02:47 PM
Rubia Torres
‎2011-09-12 10:18 PM
‎2011-09-12 10:32 PM
‎2011-09-13 01:05 AM
‎2011-09-13 03:46 AM
jwsoldierdad wrote:There is a new feature in 15 that shows the roof in plan based on the true 3D view.
I have done as you suggested before and for some reason that is what is causing the problems. i have found a temp. solution. This solution is to take the individual pic points and stretch them to the location they need to be. If there is an easier way than this I would like to do it.
‎2011-09-13 03:57 PM
Barry wrote:No, it's not showing the true 3d view. It's always a view taken above roof even if your cutline is below the roof. So you will not see the interior /bottom-edge of roof on plane, just the top-edge.jwsoldierdad wrote:
‎2011-09-14 04:12 AM
TurboGlider wrote:It is a true 3D view (from the top).Barry wrote:jwsoldierdad wrote:No, it's not showing the true 3d view. It's always a view taken above roof even if your cutline is below the roof. So you will not see the interior /bottom-edge of roof on plane, just the top-edge.
