‎2005-10-21 04:01 PM
‎2005-10-23 02:17 AM
‎2005-10-23 04:46 AM
Sign on to PLP file, only have admin and viewer access.If you already have a PLC, you access it through File > Open.
‎2005-10-23 02:39 PM
‎2005-10-23 07:17 PM
‎2005-10-23 07:20 PM
Tom wrote:Create two drafts from two different sign in's to the PLP file. You cannot be working directly in the PLP; you can only sign in and work in a draft file.
... But now I believe the way to do it is to make two separate draft copies from the plp.
This whole process is convoluted, not very straigtforward at all. I guess it will all be simple once I understand how it all works.
‎2005-10-24 12:42 AM
Tom wrote:you are NOT working in the PLP file . . . you are working on a copy of that PLP file called a 'teamwork draft file'. it has the extension 'PLC' and is very different from the PLP file itself. this is your fundamental error: you are never, EVER working in the PLP file.
I was working in the plp file, ...
... with exclusive access from the team leader. Send and receive changes to myself, ...no - see above. you are sending those changes to the PLP file which is NOT the draft (PLC) file that you are working on.
I was making a copy of the draft copy so two people could work on the project at home over the weekend, then update the plc. But now I believe the way to do it is to make two separate draft copies from the plp.two separate draft FILES - they aren't copies, they are TWO very distinct files even though they each contain a copy of the whole PLP file, their contents are very different: each draft contains different access permissions for the project elements. this is why each person who is to work on the project needs to sign-in and create their own, unique draft file. and when signing in, each person has to select ONLY the stories/layers,marqueed areas/etc that they need to work on. if the first sign-in is with exclusive access there won't be any of the project left for anybody else to sign in to. get it?
This whole process is convoluted, not very straigtforward at all. I guess it will all be simple once I understand how it all works.it isn't 100% ideal, but i have to add that it ain't rocket science either. you're making it far more complicated than it really is. i think that you have a very wrong idea of 'teamwork' in your mind which you're holding on to despite what we're trying to describe to you here. bottom line: get some training.
‎2005-10-24 06:59 AM
‎2005-10-24 02:43 PM
