2013-03-06
11:23 AM
- last edited on
2023-05-25
05:01 PM
by
Rubia Torres
2013-03-06 11:32 AM
2013-03-07 11:12 AM
jonbech wrote:mesh tool needs a revamp. it's antiquated
Hi. I´m encountering some problems with a terrain model i´ve created. The terrain doesn´t show the solid body.
Initially I made the mistake of setting the terrain mesh height too low, so when i put inn the z-values of each height curve the mesh went below the mesh height.
This resulted in the terrain not showing the solid body in neither section, facade or 3D view.
I then changed the mesh height after completing the z-values of the curves, to make sure the height has a lower z-value than any point on the mesh surface.
Problem is, the terrain still doesn´t show the solid body of the terrain. I am positive that the mesh height is now under the height of all z-values of the mesh curves.
Can someone tell me how to get solid body for the terrain, or is my only option to make a new terrain from the curves?
Regards Jon
2014-03-14 06:58 PM
