composite walls in plan & section
Is there a way to have a poche on a wall for plan but turn off the poche in sections? I want the rest of the composite fills to show just not the poche. I would like to avoid having to draw two walls. I use a poche in plan so that the new walls "pop". But when I cut a section the poche is too much.
Eduardo Rolon
You will need to create different pen sets for both situations. For example Pen 111 is the pen color in plan and it will print black for the "Plan Pen Set" the same pen is white in "Elevation Pen Set"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
