Tom Krowka
Text Selection in Marquee
I'm trying to select a certain text string that is repeated throughout the plan and change it. Is there any way to do with the marquee tool. I can select all the text within the marquee. What I'd like to do is select only the certain text, then change all that text at once, rather than one text block at a time.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
2 Replies 2
Yes,
1. draw marquee
2. go to Menu: Edit>Search And Replace Text...
3. use filters. Here under search "on current story" and "in all stories" you will not find search only in marquee, but it steel works.
have fun
Tom Krowka
Thanks. Never knew that was there......
[email protected]
www.walshkrowka.com
