2009-08-28
08:18 AM
2023-05-25
05:08 PM
Rubia Torres
2009-09-01 10:39 PM
2009-09-02 05:27 AM
2021-09-16 07:34 PM
Just wanted to voice that this is still an issue in AC25!
If any solution has been found, please let me know!
2021-09-21 04:17 PM
Hi Duane,
Thank you very much for the report and I am very sorry about the experience!
After some reseach, I found that the Mesh, as most 3D things in AC, has box-type Texture projection. This means there is an imaginary box around the mesh, the texture painted on its six sides, and texture on each mesh-triangle is projected from one of the six sides. The chosen side is the one with the closest direction to the plane of the triangle. So the steep triangles receive their Texture from the vertical sides, and probably from a completely different section of the Texture image than the neighboring non-steep triangles, which cause discontinuity.
What we would need is a Planar projection on the Mesh - all Mesh faces receive texture from one (horizontal) plane. Unfortunately, this cannot be set on Meshes. But, if you convert the Mesh to Morph and Select only the upper surface (Ctrl-Shift subelement selection) Planar texture projection may be set in the settings dialog.
This way the Texture fits the Morph, but the projection origin and direction will be modified. We can create a new Surface for the Morph and rotating the Surface Image with the desired angle. Then select the upper Surface and Align the 3D Texture with Set Origin.
I hope it gives a proper workaround in this case. Please let me know if you have any further questions!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2022-01-12 06:46 PM
Minh,
Thank you for the perfect explanation...
As much as I love Archicad (and that's a lot)... there are always these 1% issues that frustrate me.
I cannot give up MESH for site contours... Just not WORKABLE for the many edits it will receive over the life of the project.
But I will consider the MORPHING idea and see if it's workable.
(BTW... I'm just now reading this from your sept. post!)
2022-07-28 05:09 PM
I've had the exact same issue and came here to find if I there was a real solution instead of silly workarounds like the ones being offered here.
I have to ask, is it really that incredibly difficult to have this option? More and more, we as architects rely on ortofotomaps to create a 3d context for our terrains, and meshes are the logical solution for this.
