The most useful keyboard shortcuts for ArchiCAD
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2012-04-13
08:54 PM
ā2023-05-23
02:42 PM
Rubia Torres
I am going to create a new ArchiCAD video tutorial focused on keyboard shortcuts and quick mouse-clicks. I want to go beyond the simple browser-based reference list and demonstrate the most useful ones onscreen.
I would love to get your suggestions for this topic, to make sure I create the best reference possible.
Below is a list of the current shortcuts that I will include - please respond and add your comments and suggestions if you have any ideas for things that I may have forgotten. I'm particularly interested in the ones that seem "cool" or that you "couldn't live without" or that are "hidden" (not widely known).
THE MOST IMPORTANT AND USEFUL KEYBOARD SHORTCUTS FOR ARCHICAD
- GENERAL
Open File: Command/CTRL - O
Save File: Command/CTRL - S
Print: Command/CTRL - P
Command/CTRL - L: Layer Settings dialog
CANCEL AND UNDO
Escape key: one of the following actions (in this order) -
Cancels current editing or drawing operation (if one is in process)
Deselects Elements (if any are selected)
Removes Marquee (if drawn)
Switches to Arrow Tool (if set to another tool)
Delete(Mac)/Backspace(PC) key: Backs up one step at a time in polywall, polyline or polygon input
Command/CTRL - Z: Undo
Option-Command / ALT-CTRL - Z: Redo
COORDINATE VALUES AND PLACEMENT
x, y, r, a, d: Set coordinate values in Tracker (d = distance = r = radius)
+ (plus key): add current value (whichever coordinate is being edited) to previous value shown in Tracker
- (minus or dash key): subtract current value from previous value in Tracker
(NOTE: in U.S., two dashes are necessary; one can be a separator between feet and inches, e.g. 5-6-)
Enter key: confirms current Tracker values as shown or current mouse position, and clicks mouse
b, t: In Info Box, set base and top values for wall, beam, column, slab, stair, mesh, object
Windows and Doors accept b or t depending on which anchor is set
Roofs accept b for pivot line height
Shift-` (PC) or Custom shortcut (Mac): Create Guideline segment
Shift-Option / ALT-SHIFT:
Moves User Origin to node point (on the fly)
SELECTION
Shift key - temporarily activates Arrow tool; adds to selection set; removes from selection set
NOTE: Shift key held down while drawing or editing (rubber-band line visible) constrains cursor to nearest known angle. ArchiCAD determines the nearest end or node point and makes that the Edit Origin; then determines the nearest known angle.
W key:
Built-in shortcut to toggle between the Arrow tool and the last used drawing tool
TAB key:
When hovering with the Arrow tool or Shift key over two or more overlapping elements, cycles through elements allowing you to choose which one to select
Spacebar (holding down with Arrow tool active, or with Shift key also held down) - toggles QuickSelect (magnet) mode
Group: Command/CTRL - G
Ungroup: Option-Command/ALT-CTRL - G
Suspend Groups: Option/ALT - G
SETTINGS
Command/CTRL - T:
Element Settings (opens dialog based on which tool is active in Toolbox)
Default Settings if nothing is selected; or Selected Element Settings
Command-Option/CTRL-ALT - T:
Edit Selection Set (allows parameter setting for multiple types of elements in one dialog)
Option / ALT ā Click: Eye-dropper
Option-Command / ALT-CTRL ā Click: Syringe
Option-Command / ALT-CTRL ā Click [in library part window]:
Selects different part while transfering parameters, keeps style or āfamily resemblanceā
DRAWING AND EDITING
Drag: Command/CTRL - D
Rotate: Command/CTRL - E (NOTE: "e" is the last letter of "Rotate")
Mirror: Command/CTRL - M
Press and release Option / CTRL key:
During Move, Rotate, Mirror or Elevate command, will make a copy
Press and release Option-Command / CTRL-ALT keys:
During Move, Rotate, Mirror or Elevate command, will make multiple copies until the Escape key is pressed
Command/CTRL - U: Multiply
Spacebar
With a linear or polygon drawing tool active (e.g. wall, slab, roof, fill, line, polyline, arc, etc.)
Magic Wand (autotrace)
Drafting shortcuts in the Toolbar:
Trim, Split, Adjust, Intersect, Fillet
Keyboard shortcuts including the use of the Command or Control key by itself to Trim pieces with the scissors icon
Command / CTRL ā Click (depends on context):
Nothing selected - Scissors icon - Trim pieces of linear or curved elements
Dimension chain selected - add points
Walls or Lines selected - Adjust to meet the edge of another element
Wall(s) and/or Roof(s) selected - Trim or Crop to clicked element (roof or wall)
NAVIGATION KEYBOARD SHORTCUTS
F2: Floor Plan
F3: Show 3D Window (last-used selection or marquee will be active)
Command/CTRL - F3: Axonometric view mode
Option/ALT - F3: Perspective view mode
F4 (Mac) / F5 (Windows): Show Selection/Marquee in 3D
Command-F4 (Mac) / CTRL-F5 (Windows): Show All in 3D
F6: Last Section
F7: Last Layout
Fit in Window
Command / CTRL - '
On Windows, and recent versions on Mac: Double-click middle-mouse button
Mouse middle-button press: Pan view
NOTE: There is a free add-on called Magic Prefs that makes this work for the Apple Magic Mouse, which does not have any buttons
O key:
In 3D window, triggers Orbit mode; end Orbit by hitting O again or using Escape key
Middle-button plus Shift key:
In 3D view, activates Orbit mode; release buttons to end Orbit mode
Cursor keys (Left, Right, Up, Down):
Scroll in that direction
In Plan:
Command / CTRL ā Up Arrow: Go up a story
Command / CTRL ā Down Arrow: Go down a story
In Layout Book:
Option / ALT - Left Arrow: Previous Layout
Option / ALT - Right Arrow: Next Layout
MISCELLANEOUS SHORTCUTS
Shift ā Cursor keys (Left, Right, Up, Down):
Nudge selected element(s) the distance set in the Snap Grid
Shift-Option / Shift-ALT ā Cursor keys:
Nudge selected elements the larger distance set in the Construction Grid
Shift-S:
Turns on or off the Grid Snap (NOTE: this used to be āsā without the Shift-key modifier)
M key:
Measure tool; hit M again or Escape to finish Measure mode
Q key:
While drawing or editing an element with the mouse constrained on an angle (usually with the Shift key), this will cycle through Cursor Snap Variations.
F key:
While editing an element with a Pet Palette option in effect, this will āflickā through the available Pet Palette options.
SPECIAL MOUSE CLICKS
Double-click Magnifier Plus button: Zoom in to twice the magnification
Double-click Magnifier Minus button: Zoom out to half the magnification
Favorites palette ā double-click: Activate tool and set default;
If elements of that type are selected, injects the saved settings into the element(s)
Flick buttons [<< and >>] in Library Part Settings or Info Box:
Switches to next or previous library part; has the side effect of resetting the library part to the default settings.
Empty hole button:
In Window or Door Settings or Info Box, will switch to Empty Opening while maintaining the same width and height.
Arrow-click or Shift-click on EDGE of hole (within polygon element such as Slab, Roof, Mesh, Fill, etc.):
Select HOLE only (allows the hole to be dragged, drag a copy, multiply, deleted, etc.)
Thanks for your help in this little project!
Eric
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-04-14 07:29 AM
"Command + 1": Toggles True line weights on/off
"`": Toggles trace reference on/off (the tilde key)
Red Canoe Architecture, P. A.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-04-14 08:11 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-04-14 09:19 PM
Some other ones that I use frequently (and may be different from the standard keys for those things with default shortcuts) are:
ctrl/cmd-F: Find and Select
ctrl/cmd-minus: adjust: extends (or trims) one or multiple lines/walls to a clicked or virtually drawn line
ctrl/cmd-B: split/break a line/wall at the selected intersection (of clicked or virtually drawn line)
ctrl/cmd-shift-': zoom to selection. I use zoom extents in Eric's list the most often (ctrl-') but sometimes the project is too huge and selecting an area and zooming just it is faster.
I: intersect (walls/lines)
H: hairline / true-weight toggle (Marc's cmd-1)
Shift-I: Info Palette - info on selected elements
shift-E: SEOp palette. (Shift='S'olid, E=Element)
ctrl/cmd-Z followed by ctrl/cmd-Shift-Z (Undo/Redo): selects last created element(s)
ctrl/cmd-shift-O: open selected object in the GDL editor
shift-O: Align 3D Texture > Set Origin
shift-P: Align 3D Texture > Reset
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-04-14 09:35 PM
learned a new one from you today:
W : Built-in shortcut to toggle between the Arrow tool and the last used drawing tool
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-04-15 06:40 PM
Is there any shortcut for repeating or continue same command ( not same as toggling between selection and last command used) like Trim by holding and pressing ctrl key from keyboard
Regards,
Ratna
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-04-16 10:38 AM
Here are the steps: http://archicadwiki.com/KeyboardShortcutCustomization
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-04-16 04:17 PM
ratnabhirud wrote:Ctrl+B or Command+B will repeat the last command
Hello Eric,
Regards,
Ratna
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-04-16 05:29 PM
Jack is absolutely right!
I think it's best to teach people about what commands are most important to have shortcuts for and not focus so much on what those shortcuts are (because I know we all have slightly different variations). So just as important is the logic behind choosing which keyboard combinations to use.
Shoegnome Architects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-04-18 06:28 PM
I will incorporate some of what has been posted into the video tutorial, which I hope to record and post this week.
Eric
