The wall, which is a multi-layer structure, disappears on the plan and is not displayed in 3D
SashaArtiushova
I will be grateful if you help to solve the problem. The wall, which is a multi-layer structure, disappears on the plan and is not displayed in 3D
13 REPLIES 13
SashaArtiushova
I add another type of wall and it also has weird view
Is there something (a large slab maybe) in a hidden layer that is affecting the wall - basically trimming them away?
Turn all layers on and see what is there.
SashaArtiushova
All layers are turned on
Owais
Would you please share the file so I can have a better look at it? There are so many factors causing this; having a look is better than guessing. 😉
AC 27 | 5060
Win11 | i7-8700 CPU @ 3.20GHz | 32GB | GTX 1080
